Old 07-14-2020, 12:39 AM   #14 (permalink)
leoblack9
tinker
Originally Posted by CapriRacer View Post
There is negligible difference within the allowable rim width range.
Thank you CapriRacer, so 155/80/r13s are still on the table alongside 165/70/r13 (same diameter as oem) and 175/70/r13.
Update:
I've double checked the Charade wheels and found it that its 13x5 with an offset of ET40. Original offset of the steelies were ET45. That means these rims would stick out 10mm more closer to the fender but would have the same inside clearance towards the suspension components.
Would it be better that I find a similar offset or would a positive offset of 40 (to offset the .5" wider rim) provide similar to OEM specifications?
