What is your tire pressure? For example, there is a big difference noticable between 2.4 and 3.1 bar and it's totally free. Check the sidewall of your tires for maximum pressure and stay under it.
You could block the front grill with insulation foam or install a 'winter grill' that will also improve the airflow in the front of the car.
