/// best tires smaller lrr tires or larger regular tires ? ///
Hi all,
I run a 2003 Volkswagen Jetta TDI 5 speed so I get pretty good gas mileage as is .
Originally the car came with 195 65 R15 ecopia 422 plus tires...
When those four were out I upgraded in size to 205 75 R15 ecopia 422 Plus Tires and noticed better fuel economy due to the larger size and lrr design.
I am currently needing to buy for more tires and I've been beating around the idea of getting even larger tires i. E. 205 75 R15. however I haven't been able to find specific Tire featuring low-rolling-resistance specifically in this size.
What do you think I should do ?
should I chance the bigger tires in the hopes that the larger diameter will potentially offset any decrease in low rolling resistance design? I currently Drive mostly highway so I am thinking the extra size would help gearing wise but worried that maybe it won't help enough because it's not a low rolling resistance design?
The tires I am looking at are as follows but I am open to any recommendations or suggestions from this List or elsewhere...
Tires I'm looking at in 205 75 r 15
Goodyear Assurance a /a
Hankook kinergy St h735
Kumho Solus ta11
Uniroyal tiger paw awp 2
The tires I am currently running are Bridgestone ecopia ep422 Plus in the size 205 70 R15.
Any and all input welcome and appreciated thanks in advance.
Andrew
2003 Jetta TDI Wagon, 5 sp, 210K miles, Stock.....for now!
