Originally Posted by California98Civic
Does such a mod affect body structure integrity? Maybe not. Or is this a temporary step?
Today: finished the rebuild of my daughter's power steering rack. And on my Civic I cleaned engine bay grounds trying to eliminate periodic O2 sensor failure codes. Test drive went well.
Yes, this is a temporary step and would definately affect the structure if not replaced. In order to angle in the sides I have to sever all the connections, pie cut out the new angle, and then weld it all back. Based on the initial connections, putting it back as strong or stronger won't be a problem.
Cleaning grounds is a vastly overlooked troubleshooting step.
