Originally Posted by California98Civic
Yes!
So when I disconnected the vacuum line from the PCV valve I nearly got hit in the eye with a few drops of oil that had not made it to the catch can I am removing temporarily for SMOG testing. Seems the catch can will do some catching after all.
Have you seen the Garage 54 channel on YouTube? Some crazy Russians who do all kinds of weird things to old Ladas, with an English voiceover translation.
They stuffed a big GAZ truck 7.0L V8 into one, another they connected two engines end to end to make it a straight 8, then a third engine for a straight 12. Adding a 4th for a straight 16 didn't work out so well, mostly because the old engines are old and tired. The craziest thing they did was buying a pair of doors and all the body panels, windshield frame and top for a Porsche roadster and mounting them on a Lada.
