Old 08-03-2020, 02:30 PM   #195 (permalink)
Daox
I just went over the driver's side brake system on the Prius. I was hearing some intermittent rubbing noise that varied with speed. So, I took apart the front and everything looked great. Then I took apart the back and everything looked great. So, it went back together.
I also took the opportunity to check the tire air pressure and they were down to about 42 psi so I bumped them all back up to 50.
