ABS Module Rebuild & Repair
I am of the current awareness that most of the USA only replaces vehicles ABS modules from either dealer parts, online and local parts store. The liability and time barriers no one hardly attempts the process of rebuilding/ repair (if possible) ABS module. My limited understanding the ABS module has a pump (DC motor 12V) accumulator, distribution block (fluid) and electronics.
The pump teardown and or repair of the DC motor would entail brush & bearing replacements with rust and debris removal. This would be obvious path especially if you have a (noise/sound) from failing bearing..
Your experiences and insight are welcome with hopeful dash of critical think.
