Old 08-13-2020, 12:29 PM   #216 (permalink)
nemo
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Originally Posted by California98Civic View Post
My own mods/repairs coming along, slowly. Electrical diagnosis done, I am indecisive about my repair plan: open the engine harness to replace wires, or cut faulty wires at each connector and run wire outside the harness bundle? I prefer the former. Car runs right now, so I have access when I need it.
As you may know all electrical testing assumes a good connection, check PJs carefully. In thirty plus year of electro/mechanical trouble shooting vary rarely was the problem in the harness per say but rather at points of movement and most times were the wire exits the harness or fastened in place. Old school was to pull a screwdriver using the blade along the insulation with tension on the wire and feel the break or just pull the wire and watch the insulation stretch. If your meter probes are needle type you can just stab them through the insulation and make tests at various points.
The Following User Says Thank You to nemo For This Useful Post:
MetroMPG (08-14-2020)
