Old 08-14-2020, 10:43 AM   #14 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
This looks fantastic! You might experiment with a small air dam; the step in the tray is probably developing a pressure increase in front of itself, and an air dam could mitigate that with reduced pressure behind. Honda does this on the current Clarity, which has a similar step under the engine/transmission and a full tray behind it:
Might be worth an experiment-- I don't think it will change drag much, but should reduce lift a little.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
