Old 08-14-2020, 09:10 PM   #756 (permalink)
CeeforCitroen
I'm wondering whether with cylinder deactivation, you could actually install some sort of clutch plate in the crank shaft so the rest of the cylinders didn't even move. Then with a controlled slip, the timing is lined up with a locking pin so all the cylinders have the correct timing. The problem is the engine is designed to run balanced as a unit, so there could be vibration issues when dividing up into individual V2 groups.
The Following User Says Thank You to CeeforCitroen For This Useful Post:
aerohead (08-19-2020)
