Old 08-17-2020, 12:39 PM   #13 (permalink)
freebeard
The step leader is always downward.
Originally Posted by Wikipedia
Positive and negative lightning
Cloud-to-ground (CG) lightning is either positive or negative, as defined by the direction of the conventional electric current from cloud to ground. Most CG lightning is negative, meaning that a negative charge is transferred to ground and electrons travel downward along the lightning channel. The reverse happens in a positive CG flash, where electrons travel upward along the lightning channel and a positive charge is transferred to the ground. Positive lightning is less common than negative lightning, and on average makes up less than 5% of all lightning strikes.[43]
There are six different mechanisms theorized to result in the formation of downward positive lightning.
According to S0, positive strikes are increasing.
What the headline giveth, the last paragraph taketh away. -- Scott Ott
redpoint5 (08-17-2020)
