I don't advocate lowering the speed limit, at least not in the short term. When I cut my car loose in a Fas down the hills around here my terminal speed is easily 70+ and only then do I have a prayer of keeping up with the flow. So lowering it to 55 is a bad idea.
Although admittedly when I say I can't drive 55 it usually otherwise means I don't go that
fast.
