Originally Posted by TexasCotton
Toyota OEM 15 inch 5x100 lug wheels /rims 19 lbs (8kg)(alum/alloy) from what the forums and others have stated additionally the tire is somewhere around 17lbs coming in at 36 lbs....
Regarding tire weight, I asked Michelin and Bridgestone for oficial numbers while searching wheels for my previous car.
Michelin Alpin 4 195/65 r15 7.8 kg 17.2 lbs
Michelin Alpin 6 195/65 r15 8.2 kg 18 lbs
Bridgestone Turanza T005 195/65 r15 7.5 kg 16.5 lbs
Bridgestone Turanza T005 205/60 r15 9.3 kg 20.5 lb
I switched fdom my winter setup steelwheel 6jx15 et45 + Alpin 4 15.9kg 35 lbs total per wheel to Autec Wizard 6.5jx15 et38 + T005 14.3 kg 31.5 lbs total per wheel and didn't notice a difference. But I only drove them for 2 tanks before the engine started doing weird things.
Originally Posted by GreenTDI
If you have the new Octavia 4, Cd is 0.26. The previous model has 0.31 indeed.
It's an Octavia 3, probably one of the last ones build in 06.2020. I needed it quick so I went for a car that was on it's way to the dealer. So no TDI evo
![Frown](/forum/images/smilies/frown.gif)
but atleast I have proper buttons
From what I read so far the O4 has great fuel consumption. Wondering if they'll bother doing a greenline model, for the O3 it was only available pre facelift.
