Old 08-27-2020, 01:44 AM   #75 (permalink)
JulianEdgar
The Taycan, while certainly a 'fastback,' is not a streamline body. It's a composite, with the greenhouse independent of, and glommed onto the main body.
The roofline of the Taycan is a bit too aggressive, there's too much pressure regain for the length of the roof, compromising the boundary layer. The spoiler helps reach out to the streamline contour. It's not as good as simply lofting the end of the body.
Upper surfaces of the body, flanking the greenhouse represent very little deceleration, with high velocity, low pressure. Nothing like a streamline body, in which the body would boat-tail from the same point as the roof apex, building pressure the entire length of the aft-body.
I believe that a close reading of Doctor Wolf supports everything I mention. It's at home, not at hand.
Classic example of Aerohead changing the proposition. Now it's not about fastback cars, now it's about - well... I don't know quite know what.
Can someone explain?
Reading it again, I think it might be Aerohead telling Porsche how they could have made things so much better by following a mythical streamline body - one that apparently has low drag and low lift!
Gosh, what a shape that would be - and yet, as far as I know, no-one has ever produced such a road car with this measured data (low drag and zero lift) available.
All these professional car company aerodynamicists, yep, they're just stumbling about in the dark waiting to hear from Aerohead.
aerohead (08-28-2020)
