Old 09-24-2008, 09:17 AM   #1 (permalink)
davchar
Sensing Injection with Flexiforce Sensor?
Hi All,
I have a mechanically injected diesel engine. I have been assessing options to get fuel usage information for the MPGuino.
I'm wondering if there is any definite reason why a Flexiforce sensor wrapped around one of the injector lines would not work for sensing injector firing and duration. The details of the sensor can be found here: SparkFun Electronics - Flexiforce Pressure Sensor - 25lbs.. I'm not sure whether the 1, 25 or 100lb sensor would be best.
If there is a chance this sensor might work I'm happy to give it a try as it is significantly cheaper then going the dual flow transducer route.
Cheers,
David
