Old 08-28-2020, 02:30 PM   #17 (permalink)
oil pan 4
As long as you never start it below 50 or 60 degrees imperial the multi viscosity oils don't give you any benefit.
That "old oil" you have is likely SJ rated and is packed with additives compared to modern SN rated oil and is perfect for engines that don't have roller everything internals.
