Old 08-28-2020, 07:09 PM   #78 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by California98Civic View Post
Lift is one of the things we're interested in here. However, it is not THE thing. For modding purposes and general learning about about aero, I am curious about the pressure coefficient and how it relates to lift.
Here is the Figure 5. What, aerohead or anyone, do I misunderstand when I read this as demonstrating that you were right to say a fastback shape would have a greater pressure coefficient at the rear of the roof?
The pressure coefficient at the rear of the roof does not matter, in and of itself. Lift is determined by the effect of the pressure over the entire surface area. This figure clearly shows that the notchback achieves higher peak pressure than the fastback, at the base of the rear windshield, while the figures comparing lift and drag show that the total pressure on the rear of the cars is higher on the notchback than on the fastback.
Pressure can be thought of as a scalar, while the surface area is represented by an area vector A. Think of the surface area of the car body as a bunch of small area "cells," each a vector dA normal to the surface at that point, with a certain discrete pressure p acting on each cell (directly proportional to the pressure coefficients in the figure). Multiplying each surface area "cell" (vector) by the pressure acting on it will give you a force, with a direction also normal to that bit of surface (since dF = pdA, the resulting force points in the same direction as the area). Sum all these force vectors together (integrate pdA over the whole surface) and you'll get one force vector representing the force acting on whatever part of the car body you chose as the area--the rear part, in this case. Break that force vector into its components along the x, y, and z axes and you have drag (or thrust) in x, side force in y, and lift (or downforce) in z acting on that part of the car (along whatever arbitrary axes you choose). Do this over the entire surface area of the car and you will get the total drag, total side force, and total lift. The aerodynamic forces result from the local pressures which result from the local velocities which result from moving the car.
Is that what you're asking?
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 2 Users Say Thank You to Vman455 For This Useful Post:
aerohead (09-02-2020), California98Civic (08-28-2020)
