You are in a really hot room using that, I looked the model up online, and noticed a Nvidia GPU sticker... A high powered GPU (big heat) in a laptop (no cooling) running for work (high load, long run times) in a 100F room.... (high stress) I think the CPU would throttle down to low power mode at 150F/65C, only 50 degrees headroom... I think you should return it ASAP if its not to late, you ran that thing hard for the time you had it. yeah.. abuse that warranty... buy a desktop with big fans or a Toughbook
