Old 09-01-2020, 07:36 PM   #98 (permalink)
freebeard
Originally Posted by kach22i
Has anyone superimposed the Mair's tail with the Aerodynamic Streamlining Template Part-C?
My recollection is that the blunt nose and rear taper from Mair, minus the constant-section center approximates [one instance of] Thee Holy Template.
I don't know how you get to that - Aerohead has repeatedly stated that his theories are correct in the face of contrary test results.
I've met with aerohead on The Salt and at Darko.
I am pretty amazed that you are now nominating another template for rear add-ons. This is just continuing the problem!
On Internet it is customary to post a wrong answer. That how you find out the right one. I documentated the pushback against the Template that was available before you started posting.
My intent really was to draw out the Morelli design that was all forebody with max camber at the C-pillar and a 45° chamfer instead of a wickerbill.
The closest I can find is this [Honda?] concept:
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
aerohead (09-02-2020)
