Old 09-02-2020, 07:30 AM   #1 (permalink)
Andyinchville1
//// Level out car for better aero ? /////
Hi All,
I drive a 2003 Jetta wagon with TDI engine and got to thinking the other day that if I level out my car (the rear currently sits higher than the front) I actually may get better aerodynamics ( I say this because if you extend your arm out the window and make your hand into a "wing" then when it held flat it takes little effort to hold it but if you angle it up or down you have to use extra effort to hold it).
I realize it may not be much drag but thinking every bit helps... what do you think ? has anybody leveled out their car found found that it helps aero ? ( I realize lifting is generally viewed as hurting aero but in this case I think a neutral "wing" may offset any extra bits hanging in the wind ? .... I would only be increasing the front an inch or two with commercially available kits.
Thanks in advance for any and all help.
Andrew
2003 Jetta TDI Wagon, 5 sp, 210K miles, Stock.....for now!
The Following 2 Users Say Thank You to Andyinchville1 For This Useful Post:
aerohead (09-04-2020), GreenTDI (09-03-2020)
