Old 09-03-2020, 06:35 PM   #7 (permalink)
freebeard
Put bigger tires on the back. (example is lower profile on the front, stock on the back)
I'd be concerned that raising the front would increase front lift. Generally, you want minimal air intrusion at the front tires with a central jet feeding a rear diffuser.
Nose-high increases frontal area and makes the underbody a converging duct, tail-high exposes the underbody to the wake.
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
