Old 09-03-2020, 06:44 PM   #6 (permalink)
JulianEdgar
Thanks OP, I hadn't seen this one before:
What do you make of the internal dotted lines? They seem to imply that pressure differentials transmit through a solid body. ???
The lines in the upper part of the diagram show flow directions. The dotted lines show flow around the car.
The key point is that the pressures shown on this diagram do not apply to real cars.
freebeard (09-03-2020)
