09-04-2020, 01:56 PM
#26 (permalink)
lift
Originally Posted by JulianEdgar
With respect, this is likely to just send us back to the BS from which the original garbage descended.
Note: I am not saying that these cars are of no interest, or they they were backward at the time. In fact I am a great fan of them.
But....
The Cd values recorded at the time for these cars are highly unreliable, as has been demonstrated when full-size cars of the past have been tested in modern wind tunnels.
...and...
The designers of the time cared nothing about lift, and so basically all the shapes shown are of such high lift they would never be released by any responsible car company today.
...and...
In general, the designers were not aware of the drag resulting from trailing vortices, and so attached flow was often seen as an end in itself.
More than anything else, these factors explain why no current cars look anything like these cars. For exactly the same reasons, it also explains why using some sort of standardised approach (a template) based on these ideas is usually a pretty bad idea, and using such a template as some sort of model for changing an existing car is an even worse idea.
You're speculating.
