Old 09-04-2020, 06:30 PM   #24 (permalink)
JulianEdgar
Chevrolet was allowing the following for their last-gen Corvette:
* coolant- 239 F
* engine oil- 284 F
* ECU- 221 F
* Supercharger- 289 F
* Intercooler coolant- 131 F in
176 F out
* Brake fluid- 338 F
* Transaxle lube- 284 F
I don't have the reference but those temperatures are very, very high - I'd guess the absolute max before destruction.
For example, an engine oil temp of 284F (140 degrees C) is above the breakdown temp of a conventional oil, although not of a fully synthetic.
Those supercharger fluid temps would imply an intake air temp of over 176F (80 degrees C) - and you never ever want to see that on a forced aspiration car.
Coolant temp 115 degrees C - and so on...
The OP is now 12 years old, so I won't bother answering that.
aerohead (09-16-2020)
