Old 09-05-2020, 10:07 AM   #148 (permalink)
Snax
Lord Vader - '15 BMW i3 REx
90 day: 35.06 mpg (US)
I had no luck extending mine, either. Couldn't say why.
I think there is just too much voltage drop. I figured that people were able to do a similar extension with Raspberry Pi cams, so it would likely work.
Regardless, the new setup is easily as good as the extended DVR cam would have been - except for omitting the DVR. I'm sure there is an easy solution for that with a little more work on it, but I don't really feel like it is necessary with the wide views of the front and center cams already recording.
I also just took the car for a spin in full darkness, with no moon and overcast sky, and the side cams are outstanding, bettering what I can see with my eyes directly. The monitors are a touch too bright on the lowest setting however, and I may put a light tint over them to tone it down, but the power connector has a switch on it to turn them off on darker roads. They are fine however in street lighted conditions.
2015 BMW i3 REx
2011 Ford Flex SEL AWD
The Following User Says Thank You to Snax For This Useful Post:
aerohead (09-09-2020)
