Old 09-07-2020, 09:36 PM   #7 (permalink)
JulianEdgar
Took a pic of the dash on the highway today:
Ride heights on bottom line - front left, front right, rear. Measurements are in centimetres and should all be zero at this speed after 15-20 minutes. So rear ride height is 1mm high in this pic.
FYI:
21.8 = AFR
5 = gear
103 = km/h
73 = kPA manifold pressure (must have been going slightly downhill)
Bar graph = tacho
Bottom line can show lots of different data, switched through via a button.
Blue light (just visible) shows I am in lean cruise mode.
aerohead (09-09-2020)
