Old 09-09-2020, 07:29 AM   #326 (permalink)
AdrianD
AdrianD's Avatar
Since I dont use this car in the winter, I'm OK with drilling little holes underneath for mounting brackets, in this case for the skirts.
Imagine my surprise when I punctured the right side rocker panel:
It ran for a surprisingly long time! Maybe a cup or 2 of water came out.
I'm not sure how the rocker is supposed to let rainwater out (or how it gets in), but this one is obviously blocked... or used to be.
There are drain holes on each side of the jacking points on the rocker seam. Too bad everybody closes them, then the rockers rust from the inside out
The Following User Says Thank You to AdrianD For This Useful Post:
MetroMPG (09-09-2020)
