Thread: tire diameter
Old 09-24-2008, 01:44 PM   #51 (permalink)
tasdrouille
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Originally Posted by CapriRacer View Post
No. My understanding of footprint length is that at a given load/pressure the length is essentially independent of the width - everything else being equal.
I don't get why if I switch to a tire that is larger, the contact patch would be larger. The load on the tire being the same and the pressure too, the contact patch should keep approximately the same area. no?
My understanding of RR is that most RR comes from the deflection of the tread and that the flexing of the sidewalls is coincidental. Put another way, if I take 2 identical tires, but one is pretty much worn out and the other tire is new - and then use the same load / pressure, not only would the footprint be the same size, but the worn tire will have substantially lower RR.
My understanding is that the thing that creates the most hysteresis (heat generation) is the thing that has the most mass - the tread rubber.
I can't disagree with the first part, as you remove material from the tread hysteresis can only go down (all else equal).
The second part I had problems with, so I went to look back at the 80% of total hysteresis from sidewalls figure I had in mind. Turns out I was wrong. In the transportation research board special report 286 there was the following :
"In particular, the tread contains much of the hysteretic material in
the tire. Not only is the tread made of rubber compounds that are
designed to improve wet traction, the tread band also contains relatively
large quantities of material to prolong wear life. Studies indicate that the
tread alone can contribute more than half of hysteretic energy losses in
a tire (Chang and Shackelton 1983; Martini 1983; LaClair 2005)."
So thank you for pointing out my error. Sidewall hysteresis plays a role, though it's not the most significant.
www.HyperKilometreur.com - Quand chaque goutte compte...
