Old 09-11-2020, 12:47 PM   #30 (permalink)
aerohead
'there's plenty of data that shows that.'
Originally Posted by JulianEdgar View Post
You keep talking about wing profiles having the ability to develop zero lift at certain angles of attack. That's fine - there's plenty of data that shows that. Trouble is, it's another of your argument red herrings.
For example, let's give The Template a negative 5.6 degree angle of attack (as you nominate for the Clark Y) and then let's add a suitable underfloor profile (red).
I'd be pretty confident that lift would now be waaaay down. Trouble is, it's also now a completely different shape...
* Finally, after a year or so, you publicly announce that all wings are capable of zero-lift. This is real progress. Thank you!
* I've provided the underbody profile. It's basically flat until the long, 2.8-degree diffuser completes the belly. The rest of what you see is the wheel fairing package. SAE 'approach', breakover', and 'departure' angle limits for a passenger vehicles are respected.
* As to a car-width 'wing section' for an automobile, this was tested by Kamm at FKFS and returned Cd 0.21 as a lange-heck.
* Adding tumblehome reduced the drag to Cd 0.1764.
* Adding body camber and boat-tailing produced Cd0.1481.
* And the long diffuser takes it to Cd 0.1231 ( Template car measured Cd 0.1201 with crappy wheel fairings ).
* In front elevation, the 'template' car approximates a semicircle in cross-section. There isn't a flat surface on the car anywhere. It's all compound surfaces.
* A couple of 'wingtips' joined together would be a more accurate characterization of the form. It's a streamline half-body.
* The sides mirror the top contour.
* Pressures alongside are very close to up above.
* There is no vorticity.
* Boat-tailing creates continuous cross-sectional contraction and surface area reduction, all the way to essentially zero, over the latter 2/3rds of body length. That doesn't make for a very good 'wing.'
* Passive pressure acting over the aft-body would be at the highest positive values observable.
* Active suspension and reduced ground clearance offers opportunities.
* Active suspension offers body inclination opportunities.
* The tail can be 'deployable' as with Hucho's Figure 8.63.
* Static wheel loading due to travel weight may make the whole 'lift' issue a non-starter.
As a piece of crap, Spirit is quite stable at 108- mph. In crosswind, exposed ,on an elevated interstate highway. With wind tunnel tuning I would venture that it could perform any 'normal' driving functions without drama.
