Old 09-24-2008, 01:21 PM   #7 (permalink)
Daox
Thanks for the answers guys.
To go along with this question, what is considered the max amperage you can pull from a battery? My thinking is that you'd have to have enough batteries in parallel if you wanted to run something that pulls a lot of power, even if it is only for a short time. Also, what is generally considered the max charging amps? I'm thinking lead acid here, nothing fancy.
