Old 09-12-2020, 07:13 PM   #18 (permalink)
JulianEdgar
Originally Posted by skyking View Post
Your'e obsessed with posting about lift. Is it because you've got the instrumentation to measure it?
I can measure changes in drag and panel pressures too, and I often write about those as well.
In the realm of economic driving, the destabilizing effects lift are not an issue. Neither is adding downforce.
Unless you never exceed 80 km/h, not true.
What we care about here is drag. We do indeed measure it with adding mods, then doing tuft testing, A-B-A testing, coast down tests. Long term gathering of data over the same ground, day after day.
Well, any coast down testing that you can perform on a normal road is quite invalid - it's one of the things that Aerohead states here that is right. I am not sure what your point is with your other tests - they're great!
We don't have many million dollar wind tunnels.
Neither do I - I am not sure of your point.
In the speed ranges in question, measuring lift is a roundabout way of measuring a component of drag.
That does not appear to be the case. An example is the Porsche Taycan that has lower drag at higher lift (ie spoiler down).
It is by no means the source of all drag. Not even close.
I've never suggested that is the case
I suggest you climb down off your well beaten dead high horse and try participating in a civil manner.
Well, the 'civil manner' of the group has allowed complete misconceptions and erroneous advice about car aerodynamics to flourish for a long time. Might be a bit better if BS is called out and not brushed under the carpet.
You have a great deal to add here. Try adding it and not contesting every other thing you see.
I contest only misconceptions, errors and misleading advice. Unfortunately, there is a lot of it.
aerohead (09-16-2020)
