a hs gym sized chunk of waste would fit quite nicely 5km under ground in a shutdown diamond mine in the arctic circle 500km from the nearest human... just sayin.
I watched a doc on Chernobyl. There was home video of the control panel operators pouring vodka shots ON THE CONTROL PANEL and getting wasted when they should be watching... its pretty easy to run things better than that.
North Americans WILL NOT reduce their consumption. It will ONLY increase. Don't kid yourself. The only way for it to be reduced is for there to simply not be any more power to make waste affordable.
