Old 09-16-2020, 12:20 PM   #37 (permalink)
aerohead
advice
Originally Posted by JulianEdgar View Post
Yes I do say 'uncritically'. Ancient, long threads are irrelevant to people coming here and seeing bad advice. Errors need to be called out when they are stated - not 'thanked' as they often are. And the more the errors are repeated, the stronger should be the pushback.
It's just one of those strange beliefs I have - people modifying cars shouldn't be given bad advice. Odd I know...
I mean, you only need to look at the title of this thread - absolute misleading rubbish, that I have seen given here as direct advice to someone wanting guidance on a rear spoiler design.
The template is simply a derivative of everything aerodynamicists implicate for low drag design. It's provided for information. Like a 1.5-radius, street-ell in plumbing or ductwork.
If it's cutting into your credibility as an aerodynamic 'GURU' I make no apologies. It is simply what it is.
There's no way you can logically attack it. Your ad hominem attacks on me won't undermine it's physics. You have no scientific tools at your disposal with which to attack. You're a bad loser. Grow a pair.
