Old 09-16-2020, 06:18 PM   #12 (permalink)
JulianEdgar
4) inviscid is also used to describe actual, ' real' fluid, outside the boundary layer, which telegraphs pressure through the boundary layer to the lowest strata of air, adjacent to the surface of the model, measured as local static pressure.
Can you provide me with a reference for that? I've not seen 'inviscid' used to mean that (except in what you write).
aerohead (09-18-2020)
