Your boss has a department to run and your job is to be part of that department. If you define your job in another way, you've decided that you aren't actually under your boss. This can work if it helps your boss please his boss, or if that boss notices you and protects you, but otherwise you're dong it wrong.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
