Old 09-17-2020, 03:10 PM   #31 (permalink)
samwichse
Thalmaturge
CHONK - '18 Honda Clarity
After installing the Scott's solid metal undertray on my Insight (instead of the two smaller pieces that cover 1/3 of the area under the engine each), I found the car took longer to warm up and had a harder time maintaining coolant temperature under lean burn conditions on the highway.
I ended up having to partially block the lower grill area to compensate.
The Following User Says Thank You to samwichse For This Useful Post:
Nautilus (09-18-2020)
