Originally Posted by Vman455
Yep, just guessing a random mod based on tuft behavior. I will say that both mods are moderately-to-very common on Priuschat, but to my knowledge have never been measured by anyone using them (although Altered 1 is often claimed to "improve downforce" by people who fit it on their Prius).
I thought so too. I could see some of the movement of the outermost tufts that the camera didn't pick up so well, but I'll comment on what I think is happening after I pressure test (if that confirms what I suspect).
Yes, could be some trailing vortex development down the pillars.
Bingo! Almost exactly right--I taped a 21mm high lip to the top edge of the window:
Glad I got it right! And it may well reduce lift - but at a penalty of lots of drag.
Yes, this one is more difficult. There's no disruption to the baseline flow pattern, but the tufts toward the trailing edge of the window are behaving slightly differently. (Actually, now that I look again the tufts at the leading edge have changed behavior slightly as well).
Now that I know it's a common mod, I'd suggest (un-needed) vortex generators have been added at the top of the window.
