Thread: Lift
Old 09-19-2020, 05:22 PM   #29 (permalink)
JulianEdgar
Originally Posted by MeteorGray View Post
Quote: "Flow patterns on modern car shapes (eg notchbacks) are quite different. This is a primary cause for your confusion - car shapes (and their flow patterns) have changed, but you act as if they have not."
I have a hard time following all this, but it's interesting nevertheless.
If you strip away the obscure language, it's actually easy to understand.
Old shape cars (eg notchbacks) had flow that separated at the end of the roof. So, my old W123 Mercedes shows flow separation from the end of the roof:
Note the tufts on the rear window and boot / trunk lid show separation (they're whirling around, not lined up in flat rows.) Basically, the wake extends to the height of the roof.
Conversely, modern cars have attached flow across the boot / trunk:
Note the tufts on the rear window and boot / trunk lid show attached flow (they're not whirling around but instead are lined up in flat rows.)
As far as I can ascertain, Aerohead believes the flow pattern shown on the Jaguar isn't real, in part apparently because the rear contours of the Jaguar dip more sharply than his Template. He believes that the flow is really separating far forward. (In fact, he has said at least once that it is separating at the windscreen header rail, believe it or not.)
Now to lift. If we look at the old Mercedes, we can see the boot / trunk lid is in separated flow, so in effect it is within the wake. The wake is a low pressure area and this low pressure is bearing on the boot / trunk lid, so causing lift. So in the old cars that Aerohead likes citing, in fact separated flow was causing lift.
But this theory is obviously quite invalid for modern car shapes (there's almost no separation), so where is the lift coming from? It is coming from the airflow wrapping around (ie attached to) the upper curves, so generating low pressures.
Here those low pressures can be seen on Jaguar CFD (hotter colour = lower pressures):
Not the low pressures all across that curved roof and part way down the rear window. The blue areas show that in fact Jaguar claim positive pressures on the boot lid (achieved by the rear spoiler).
My Insight shows it well - note the measured lift across the upper curves. The Insight has attached flow on all upper surfaces. (Length of arrows shows magnitude of force.)
So:
  • the shape of the car determines the airflow pattern
  • car shapes have changed a lot in the past 60 years
  • theories of airflow need to take into account what is happening on current shape cars
Unfortunately, Aerohead has built entire theories on faulty and / or outdated premises, and then extrapolated them to the point where a great deal that he writes is completely wrong. (Not everything, but a lot.)
He then denigrates the real experts. Who? Well, he has made adverse comments here on a number of aerodynamicists, including the head of Porsche aero, the head of Jaguar aero, an F1 aerodynamicist, a former Tesla aerodynamcist - and so on.
So he doesn't read current aero literature, and doesn't want to learn from real experts.
That's not a good combination for giving people advice!
aerohead (09-23-2020)
