Old 09-20-2020, 04:44 PM   #3 (permalink)
JulianEdgar
Coincidentally, I just came in from the shed with these speakers I have a new amp for. They're half-finished 7 1/2" plastic globes. I'd removed the original single cone speakers and stored them with three-way speakers. I was just going to stuff them with insulation, but now I want a port. How is you position the port relative to the backside of the speaker?
I'll bet the flowerpots' mass makes a difference, but you go to the stereo with the speakers you have, not the speakers you want.
Ported speakers need to be designed so that the port matches the requirements of the driver you are using. You can't really just guess it. I use Woofer Tester to test the speaker and tell me the required port size (length and diameter) for the results I want.
