Old 09-23-2020, 01:53 PM   #52 (permalink)
aerohead
other
Bad example then? Can you suggest any other?
Other 3-wheelers with exposed wheels? If that be the case, none would qualify.
Low drag requires integration of the wheels into the body, and an aerodynamic singularity.
The ARCIMOTO, Edison-2, Peraves Monotracer, Aptera, etc., are all in a separate category from coupe / sedan, notchbacks, fastbacks, and squarebacks.
Like the difference between a lakester and a streamliner.
