Originally Posted by M_a_t_t
I don't understand. I posted a gif and a link to both sides being tested. Unless you mean it needs to be the same side compared?
Sorry, I assumed that I was meant to be commenting on the flow pattern with all the white panels attached? (ie versus no white panels?)
If all I am meant to be commenting on are the separation edges, then yes, they seem to be working fine. (But I have found with separation edges that measuring pressures is a better way of assessing their effectiveness.)
