Old 09-26-2020, 12:38 AM   #9 (permalink)
Grant-53
I have a supply of 9 mm aluminum honeycomb but that is not as available as PEX tubing, Lexan, or Coroplast. I went to PEX first due to crash concerns as the neck is vulnerable. I might try short pieces of PEX filled with foam along with the elbows. Fiberglass was used by Craig Vetter on motorcycles but that requires building a mold. I used 1 inch hex wire mesh bonded between 0.005 in. plastic tarp material on the rear cover. Again the need for a rigid space frame. I will look into 1/2 in. foam insulation board bonded to plastic or aluminum sheet. Cloth lycra has been used and I would like to see something waterproof. Padding at the should and hip would be a plus. I appreciate the suggestions.
