Originally Posted by Grant-53
Fiberglass was used by Craig Vetter on motorcycles but that requires building a mold.
I think to get decent results you're going to need something with compound curves at the front. I'd probably try blowing a dome from acrylic sheet. Acrylic domes are also available off the shelf in lots of sizes.
In the past I have cut one up with a 1mm cutting disc in an angle grinder.
