Old 09-27-2020, 04:14 PM   #275 (permalink)
101Volts
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.73 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
Vehicle: 1990 Mercury Grand Marquis Station Wagon.
Yesterday:
Installed Rear Wheel Cylinders (Drum Brakes.) I attached the new rear brake lines to them, too.
Today:
1: I got the Rear Brake Hose on, and installed the brake lines to it. It took extra time, since one side of the hose has a larger brake line screw hole than the other (why?) and I needed to buy a size reducer.
2: The Brake Lines in the Rear and the Front Passenger Side have been Ziptied down.
3: I put some Cheap Brake Fluid in the Master Cylinder, to suck up any possible moisture in there. I'll remove it before adding Amsoil Brake Fluid.
Near Future:
1: Re-install the Gas Tank and Lines.
2: Replace the Fuel Line & Vent Line on the passenger side by the engine, in the last few feet. I didn't realize how rusty they are, by the engine.
3: Bleed the Brake Lines.
4: Inspect for leaks.
Farther Future:
I ought to replace the Oil Pan; its integrity is concerning, but seemingly not horrible. I think I need to raise the engine by a few feet, which I've never done before, but I'm sure that it's not too big of a problem.
