Old 09-24-2008, 09:37 PM   #11 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
I appreciate your perseverance. Can you try the separate battery trick thusly:
Connect spare battery ground to vehicle ground.
Connect spare battery + and ground to the guino 12v input.
connect vss and inj as normal.
See if that helps at all.
Also Did you change vssdelay to 3 to fix something?
FYI, The high cpu numbers are only when you use setup. It clears back to normal at next power cycle.
