Old 09-30-2020, 12:36 AM   #21 (permalink)
cRiPpLe_rOoStEr
Vesa, are you related to motorcycle racer Kari Tiainen?
Originally Posted by pete c View Post
I've thought the same thing about incorporating some sort of motorcycle swingarm suspension. Use a fully enclosed belt drive for low maintenance.
I would eventually consider shaft drive instead of belt, or a setup similar to what is fitted to the classic Vespa with the gearbox resorting to the swingarm as its case.
