Old 09-30-2020, 04:38 AM   #26 (permalink)
zedhead
Lingo - '02 Citroen Belingo van
Ceecee - '03 CCM 644 DS
Originally Posted by GreenTDI View Post
O yes indeed. You still find them for sale, all with the 1900 cc non turbo diesel engine and +200k miles on it.
And its predecessor, the Citroën C15, is still in use
Big advantage of these army vehicles is that they are well maintained.
My Berlingo is a 1900cc normally aspirated, as was my C15 I had before it. Both slow as hell, but I have bikes if I want to go fast... Fuel economy isn't brilliant, but I'be got over 600 miles out of a tankful several times, and found that moving the front number plate so it blocked the intake in the bumper improved the consumption by about 3mpg! Raising the tyre pressures above standard also helps, with no detriment to handling or braking (cheap tyres that aren't great at either in the first place...)
Biggest problem I've encountered is that aftermarket suspension drop links are rally crap, and don't last long at all before the suspension knocking stats again...
