Old 10-02-2020, 08:53 PM   #41 (permalink)
jjackstone
Originally Posted by mpg_numbers_guy View Post
Electric vehicles aren't free mpg. To convert to mpg properly you have to consider the cost of the drive rather than the watts involved. For most people electric vehicles are more expensive to drive unless you can charge them at home cheap or have access to free charging.
True. But if we do the conversion, you have about 33.7 KWH/ GALLON of gas. So if a gallon of gas cost $3, then a kwh would need to cost about 9 cents to be the same cost as gas. Most of the country has higher electricity costs than that especially California. However, a "gallon" of electricity will get you two to three times as far a gallon of gas. So your cost per mile varies more with where you live .
For example, a person I talked to would spend $5 to charge their Prius Prime battery, for 25 miles. That's $0.20 per mile. At 60 mpg in hybrid mode and $3/gallon running on gas would be $0.05 per mile, making electricity 4x as expensive, giving them an equivalent mpge of 15 mpg, even if the Prius readout claimed "199.9 mpg".
Wow! Someone was silly enough to pay almost 60 cents/kwh. Prius Prime battery is about 9 kwh. Additionally I'm pretty sure that the Prius is capable of charging the battery while it is running. Flawed logic in your mpge calculation. Mpg vs mpge is a physical number. The cost per mile is a separate issue as I showed above.
Vintage vehicles are typically larger and less aerodynamic. A few models were produced for aerodynamic efficiency, but would be hard to find. And it would need to be smaller or more aerodynamic than the already crazy efficient G1 Insight. Drivetrain could be from a G1 Insight, but then you'd have to fabricate custom mounts, etc. for it. There's a guy on here who swaps Prius drivetrains into classic cars, but his projects take a very long time.
Aerocivic.com might be worth checking out.
JJ
