Old 10-03-2020, 03:04 PM   #27 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Alright just changed the oil in the Prius. 172k. I put in 5 quarts 9000 miles ago and 2.1 quarts came out. So the car consumed 2.9 quarts. That's similar to 1.6 quarts every 5000 miles. Just changed the oil with a can of 6 cylinder engine restorer and some more 0W-20 oil. So 5 quarts total goes back in and we will see what comes out.
Update:
YUP THE PIG IS SUCKING OIL!
Air filter is clean after 80k miles now. Top side of the throttle body is clean. Back side of the throttle body was oily. Got a screw drive to prop it open... There is literally a reservoir of oil in the intake.
Time to go to Prius Chat and complain.
ID:	29256   Click image for larger version
ID:	29257   Click image for larger version
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
Joggernot (10-04-2020)
