Originally Posted by JulianEdgar
2.3 percent throttle variation? Seems a little high.
I didn't bother using the throttle stop after the first few tests because I could manually hold the throttle to 1 per cent (watching the live TPS percentage readout on my Motec dash) eg 20-21, 20, 20, 19, 20, 20, 20, 21 (etc).
One thing that I have learned though is that you must enter the test straight at dead-on the same speed and then move to your throttle stop position. In my case I enter at exactly 100 km/h (there's a tree I sight against) and then go to throttle-stop position, which might then raise or lower that speed by the end of the straight, depending on the aero changes.
But best test is windows open / windows closed - then at least you know you're measuring real stuff.
I thought the 2.3% seemed high as well, but thats what the numbers say  .
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
